posting in the Mercury Section instead of the Design Center since I don't anticipate doing believable 2020 chops in the near future
Mission2020: The RETURN of MERCURY!as a boutique Brand of small(er) Luxury vehicles that imho the Lincoln name cannot effectively offer,
fulfilling the Small Mercs Theorem as the *FUN* side of Lincoln:
2 sport'coupe'/hatchbacks------------------.......wlb-----ovl----width
-------"C3, Coupe3, Capri" 3-door-----104Ό---173----72½
-------"C5, Coupe5, or ......" 5-door --110.2---182----75
3 'sportback' Cuvs
-------"microSport"----------..------------99.6....166----70
-------"miniSport"------------------------108-.----179----73
-------"metaSport" 3 row* -------------112.2....194----76
3 saloon bodystyles**
-------"Micro"---------------------------....99.6....169----70
-------"Cortina"-----------------------....105.9....176----72½
-------"Milan"-------------------------.....110.2....186----75
* not positive about metaSport since it's relatively larger than "small" ... altho there's a possible RANGER tie-in
** all 'saloons' (& possibly coupe-hatches) have a dual-back structure: a hatch with a separate inset trunklid (see Skoda Superb)
Ideally all Mercury models are about the width of the next size category up in Ford vehicles...like the MKC Concept is significantly wider than the Escape.
All drivetrains for Lincoln-Mercury vehicles will be electrically assisted to various degrees
initially: 1.0EB3, 1.5EB3*, & 2.0EB4 (all gen2) as "M"(pg) light-hybrids (44-66kW);
and "R" sporty models, with approx. 22-44 kW depending on size & role.
Micro & microSport = 160hp,.------225hp
Micro & -----------& 230-250hp,..280-300hp for the rest
* see revised drivetrains' graphic below
followed by
"H", full-hybrid versions utilizing Atkinson-mode + more electrics...
(small models have less battery space & support lower total HP even with same petrol engine. see Cortina/miniSport & Milan/metaSport, or C3/Milan)
-------Micro------------.125hp = 1.0 Atkinson + 88½hp(66kW)
-------microSport----_.125hp----------"
-------C3--------------..190hp = 2.0 Atkinson + 103hp(77kW)
-------Cortina--------_.160hp = 1.5 Atkinson + 103hp(77kW)
-------miniSport.-------170hp = 1.5 Atkinson + 118hp(88kW)
-------C5---------------.220hp = 2.3 Atkinson + 118hp(88kW)
-------Milan------------.200hp = 2.0 Atkinson + 118hp(88kW)
-------metaSport------.210hp = 2.0 Atkinson + 132Ύhp(99kW)
And
a couple high-performance models adding the 2.3EB4*("R23") and 2.7EB6**("XR") but with less electrification (batteries &or capacitors), just enough for anti-slip & 'JATO'
-------C3--------------- 325hp*
-------C5---------------.400hp**
** wonder if the C5-XR could be RWD (+ front electrics)?
actually, if FLincMoCo does the CD4+rwd for the Continental, imho they could be capable of Rwd'ing JUST the XR - related chassis afterall. Then again... maybe the 2.0EB "R" with 290hp ought to be RWD too? ...plus
Would it be good/remarkable to offer a RWD "H" hybrid even though it only has 220hp?
Could the C5 be called (dare I say it...) "COUGAR"?
Would it make a difference if all C5's are RWD?
And
should the C3 be called "Capri" whether C5 gets a Name or not? ...btw, 325hp IS a lot for the basically FWD Capri but some of that is rear-wheel electrics & thinking they could be programmed to help control torque-steering.
revised drivetrains:
note:
Malibu Eco has ~20hp(15kW) electrics, 2007 Mariner/Escape had 22hp,
C-Max/Fusion/MKZ Hybrids have 118hp(88kW), Volt has 149hp(111kW)
a new type of hybrid electric add-on from the University of Tennessee
Bookmarks
