Unity Automotive has over 40 years of experience in the aftermarket automotive industry manufacturing high-quality shock absorbers, coil springs, preassembled struts, brake rotors, and conversion kits. If you’re fed up with the costs of air suspension repairs make sure to consider Unity Air Ditcher™ Air to Coil Conversion Kit. It will help you to convert your factory air suspension to a non-air steel spring suspension set up with all the necessary parts and instructions included.
This way you would be able to eliminate the risk of expensive repairs with no loss of ride quality. Created specifically for your make and model, this kit is designed to bolt on right to the existing mounting points that your air springs formerly used. Engineered for superior fit, long-lasting service and trouble-free installation this kit restores your Ford factory ride height and provides a stable comfortable ride. You can choose a kit for the front, rear, single shock and spring, or integrated as a strut assembly. No other company tests the quality and performance of their products like Unity, so you can rest assured that you get the best quality product.
Unity® - Air Ditcher™ Air to Coil Conversion Kit
Find all Unity Automotive Products on this web-page.
Forget about expensive suspension repairs with a trouble-free Air to Coil Conversion Kit by Unity Automotive!​
