2009 MANAGEMENT BRIEFING SEMINARS
Ford cuts factory retrofit spending 50% over two years, exec says - AutoNews.com
David Barkholz
Automotive News
August 4, 2009 - 1:06 pm ET
UPDATED: 8/4/09 1:40 p.m. ET
TRAVERSE CITY, Mich. -- Ford Motor Co. has cut its capital costs for factories and vehicle-building equipment by 50 percent over the past two years, said Bruce Hettle, Ford's executive director of manufacturing engineering.
Subscribe to Automotive News
Hettle said at the Management Briefing Seminars here today that Ford achieved the savings by standardizing manufacturing processes globally and by relying on suppliers to a greater degree to engineer parts.
Hettle said the strategy is on display in the production of the Ford Fiesta compact car. The assembly plants for building the Fiesta in China and Mexico are exactly the same. They have identical assembly lines, body shops and paint shops that use a new process that eliminates the need to dry primer coats before top coats are added, he said.
When Michigan Assembly in suburban Detroit begins production in several months of a new compact-segment vehicle, it will have the same layout and equipment as the Fiesta-building plants, Hettle said.
"We're starting to get the value from our global scale," he said.
Hettle declined to detail the total dollars spent annually by Ford to outfit its factories for vehicle production.
Ford only over the past two years has truly used its global resources to speed vehicle design and find the cost-savings available from standardizing production processes, he said.
For example, Ford at its Fiesta plants has reduced the floor space needed for the body shops by more than 30 percent versus a traditional Ford body shop, he said.
A tighter manufacturing configuration typically requires less machines and the non-valued added transportation of parts, said Ted Brown, vice president and general manager of powertrain systems at Comau North America.
Brown said Comau is working with Ford on a development project to tightly cluster machines in cells to assemble cylinder heads for engines. The process, which is already used at a Caterpillar subsidiary in England, eliminates the need for long assembly lines traditionally used for that type of manufacturing, Brown said.
Brown also presented at the conference today. Comau is a wholly owned factory-equipment subsidiary of Fiat S.p.A.
Standardization and designing factory tools simultaneously with the development of the vehicle has improved quality, in addition to the cost savings, Hettle said.
Over 24 months, he said, Ford has reduced factory problems at vehicle launches by 80 percent.
David Barkholz
Automotive News
