Transform your Ford Mustang into a stopping powerhouse with PowerStop Brake Kit and save up to $30! There is no time to lose, start saving now! This offer runs between May 1st and May 31st, 2022. PowerStop offers an all-inclusive package that not only offers better braking on a budget but is a direct fit with zero modifications required. All PowerStop brake upgrade kits are available as just a front upgrade, a rear upgrade, or all four wheels in one kit.
Whether it is the daily driver or performance car upgrade, both upgrades feature drilled and slotted direct fit performance rotors with a bright Zinc plating to prevent rust and corrosion. PowerStop Brake Kit will give you improved bite, more stopping power, and less brake dust than basic blank rotors and metallic pads.
Overhaul your Mustang's braking system with PowerStop! Please fill in the PDF form to get your rebate.
Power Stop® - Z26 Extreme Street Performance Carbon-Fiber Ceramic Brake Pads
Power Stop® - 1-Click Street Warrior Z26 Drilled and Slotted Brake Kit
Power Stop® - Track Day Brake Pads
