APG’s new, application-specific set of extra-wide 6.5" T Series Cab Length Running Boards has been crafted to fit the needs of your 2020 Ford Ranger, spice up the exterior of your truck, and provide you with the cab-length, non-slip stepping surface and sure footing.
APG Running Boards are made of durable Carbon Steel to perform well even in tough weather conditions. They are covered with an extra layer of Protective Black Powdercoat Finish, which makes them 100% resistant to corrosion, elements are minor scratches.
APG - 6.5" T Series Cab Length Black Running Boards
Fits: Ford Ranger 2019-2020
Notes: Mounting brackets Included.
Take a look here for more information about the new APG Product.
- Ideal solution to help you step in and out of your vehicle safely and easily
- Blow-molded design to combine light weight and durability
- Slip-proof stepping surface to ensure maximum traction in any weather
- Proven to perform reliably even in tough road conditions
- Mounting brackets included for easy, no-drill installation
- Designed to work with dealer-installed mud flaps and splash guards
