The aftermarket is highly saturated with good-looking side steps that can enhance your truck’s styling, but not all of them can withstand up to 600lbs of weight, be corrosion resistant, and offer a wide stepping area with an anti-slip pad.
Go Rhino engineers never rest on their laurels and are constantly working on improving existing designs and finding solutions to problems that were never solved before. With this new version of the Vertex running boards, you’ll get durable, corrosion-resistant aluminum construction featuring a textured black powder-coat finish, which means they will serve you a lifetime.
Go Rhino® - 5" Vertex V3 Black Side Steps
Notes:
Mounting brackets Included
No Drilling required for installation
  • Corrosion-resistant aluminum construction with textured black powder-coat finish for longer product life
  • Ellipse-shaped board provides wide 5" step pad area for greater safety and security
  • Anti-slip polymer step pad with multi-dimensional tire tread pattern allows rain, snow, and slush to drain from the surface, reducing the risk of slipping
  • Internally fortified extruded aluminum core supports up to 300 lbs per step pad-600 lbs total per side
  • Industry-leading 5-year limited warranty
Check out this page for more information about the new Go Rhino product.
