Most car and truck manufacturers leave plenty of room for improvement when it comes to horsepower and torque. An aftermarket performance exhaust can free some of the power in your engine. These systems allow for a quicker, more efficient path for exhaust gases to escape. Another good reason to add it is the subtle, but distinctly aggressive, change in exhaust note.
New for 2014 Volant has introduced a line of exhaust systems that deliver tremendous value and performance. Designed with a full-throttle muffler design, Volant exhaust systems are mandrel bent to eliminate restrictions and straight-through to maximize the airflow and performance capabilities of your Ford F-150. Using cutting-edge manufacturing techniques and engineering, Volant exhaust systems are acoustically balanced to deliver a head turning aggressive exhaust note with little to no drone. Main features are:
- Stainless Steel Bolt on Construction
- Polished T304 Tips
- Long Radius Bends ensures increased flow and volume
- Little to no droning at cruising speeds
- Improved Horsepower and Torque.
It is available for the Ford F-150 2011-2014.
Whether you're looking for more power, show-quality looks, or both, this exhaust system will change your truck for the better!
